UCS Power Tool unbind and bind to new vNIC Template
Vaikis
Hi, how to make this with power tool? As I know its possible to assign vNIC template when adding new interface, but how to modify existing ?
 Get-UcsServiceProfile -Filter 'Name -ilike XXX*' | Add-UcsVnic -NwTemplName 'NewTemplate' -Name 'eth1'
Vaikis
figured out, I need to replace with different Vnic Template
Get-UcsServiceProfile -Name "profile_name"  -LimitScope | Add-UcsVnic -ModifyPresent  -Name "eth0" -NwTemplName ""
Get-UcsServiceProfile -Name "profile_name"  -LimitScope | Add-UcsVnic -ModifyPresent  -Name "eth0" -NwTemplName "template_name"
Just forgot that
-ModifyPresent
 can be used.
Kirk J
Are you trying to modify the vnic template properties itself, or are you wanting to replace an existing template with another one?
Remove-UcsVnicTemplate
Kirk...
Vaikis
Just forgot that
-ModifyPresent
 can be used.
