UCS temperature >>50
Ibrahim Jamil
Level 6
Level 6
Hello Freinds
the temperature below is it normal ??? 
thanks a lot
Mark Elsen
  - @Ibrahim Jamil          Depends on the temperature of the environment ,
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Brian Morrissey
The image is a bit blurry but it looks like its 50c on P1_TEMP_SENS which is the internal temp on the CPU.  It's operating within spec since its below the warning and critical thresholds listed in the table, if it exceeds those thresholds the status would change
