UCS vNIC Creation Issue
craines3847
When creating the vNIC I can create 5 and the blades Associate with no Issue once I create the 6th is fails to Associate, and after a long period I get error "Remote-Invocation-Error: Out of interrupt resources"
Also at same time when Associating it gets stuck at the last line on the second screen shot.
Cisco UCS 5108 AC2 Chassis + FI6324
2x Cisco UCS B200 M5
VIC 1440
Wes Austin
What adapter policy are you using on the vNIC? Do you have enough interrupt resources available?
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/unified-computing-system-adapters/victuning-wp.html
5 Replies 5
Wes Austin
Using the Built-in Policy Win-HPN which is 512 Interrupts
Changed to the Windows policy which is 8 interrupts, and it worked.
I guess the max interrupts is 2560??
Correct. The 1400 VIC can have a max interrupt of ~ 3000 across all its vNICs per VIC adapter. So max number of vNICs that we can have with Win-HPN is 5.
If you mark the post as correct, it will be a lot easier for others to find the solution in the future.
Thanks.
