Showing results forĀ
Search instead forĀ
Did you mean:Ā
UCSB-F-FIO-785M Fusion io compatible with B200 M4?
jeroenhermans
Level 5
Level 5
We have some UCSB-F-FIO-785M cards from B200 M3 servers and are wondering if they would also work in B200 M4 servers?
I can only see the newer type cards in the B200 M4 pdf but was wondering if anyone tried it (http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/b200m4-specsheet.pdf):
UCSB-F-FIO-1600MS
UCSB-F-FIO-1300MP
Jeroen
Kirk J
Greetings.
The B200M4 does list those two cards in its spec sheet
Cisco Storage Accelerators
UCSB-F-FIO-1600MS UCS 1600 GB Fusion ioMemory3 SX Scale line for B-Series Mezzanine
UCSB-F-FIO-1300MP UCS 1300 GB Fusion ioMemory3 PX Performance line for B-Series Mezzanine
Kirk...
Hi Kirk,
Thanks for your reply. I think you have misunderstood my question.
I am asking if the UCSB-F-FIO-785M is compatible with the B200 M4?
Jeroen
I cannot find any documentation where the UCSB-F-FIO-785M is validated/tested with the B200M4.  It may have to do with the UCSB-F-FIO-785M being EOS since 2015 and the newer ioMemory3 line coming out back then.
Best case scenario, is that you get it to discover correctly, but are in an unsupported config.
Kirk...
