Update firmware for FI from 1.1(1l) to 2.0.X
Grace Zhu
Did anybody ever encounter problem to update FI firmware from 1.1(1l) to 2.0.x?
We can not download firmware into UCSM.  Tried 4 different FTP tools, tftp,  also with CLI.  It just start for 20 seconds then failed at 2%.  Is there any work around?  Any suggestions?
Give it a try with SCP it used to work fine for me.
1.1(1) is very old one. I am not sure does it supports upgrade from 1.1 directly to 2.0. Maybe you have to upgrade first to 1.4 and then to 2.0
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/upgrading/from1-1-1/to1-4/b_UpgradingCiscoUCSFrom1-1-1To1-4/b_UpgradingCiscoUCSFrom1-1-1To1-4_chapter_0100.html
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/upgrading/from1-4/to2-0/b_UpgradingCiscoUCSFrom1-4To2-0.pdf
page7 - "Only upgrades from Cisco UCS Release 1.4 and above are supported"
We tried SCP as well .  It did not work either.  We did also tried to update to 1.4 first.  The file still can not transfer to the FI.. Customer has a expert came in did a work around, and update the firmware.  I just really want to know how the expert did it.
