08-19-2020 11:18 AM
So we are having a connectivity issue inside our virtual VMware environment
First a few things about our environment:
So I did most of the classic troubleshooting, reviewing the VLANs and vNIC on the UCSM, checking the vSwitch and Port Groups on the ESXi, and we still get reports of disconnection that are solved after rebooting the VM
When checking the Fabric Interconnect MAC Address Table with "connect nxos a/b" and "show mac address table", we are not able to see the MACs of the VM in question
Is there any additional suggestion that I could check to tshoot this issue? Thanks for your help
08-19-2020 11:40 AM
You will need to do a sanity check on your VMnics at ESXi level and the vnics at UCSM level, and make sure the VMNIC #s are really the vnics that you think they are. If you aren't learning macs, then there is usually a vlan misconfiguration somewhere.
Either the port group is tagging the wrong vlan, isn't tagging at all,,, or the vnic allowed vlans aren't right (i.e. the vmnic vnic mismatch scenario)
Kirk...
08-19-2020 11:57 AM
Hi Kirk, thanks for your reply
What do you mean with sanity check?
I did check and mapped the right vNICs as the uplink of the vSwitches, and tagged the right VLANs on the vNICs
And I have no issue with the MAC of the ESXi vmNICs as they are the same of the vNICs defined on the Service Profile and are static on the Fabric, the issue we are having is with the VM MACs that are inside those ESXi
I can check the VLAN configuration once again, but I think its alright since the machines tend to connect fresh after a reboot but lose connection after a while, and its fixed with a reboot, think its more about an ARP issue
08-19-2020 01:09 PM
What teaming option are you using in VMware?
| Operating system | Supported | Not supported |
| VMWare ESXi |
08-19-2020 01:37 PM
Hey Wes, we are using originating port ID,
I was thinking about deleting even one of the vNICs to discard the factor of load balancing, but it is configured properly
