B230 M1 Blade memory add-on
I'm trying to upgrade the memory on a B230 M1 blade but the memory has gone EoL.  can i use the memory for the B230 M2 blade?  part# UCS-MR-2X082RX-C=
Daniel Laden
Level 4
Level 4
You are looking for 2x8Gb Dimms?  You will want to look at part  A02-M316GB3-2 as it is slated as the A02-M316GD5-2 replacement.
EOL/EOS for the Cisco 16GB DDR3-1333MHz RDIMM/PC3-10600/2x8GB 2R Kit
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10280/end_of_life_c51-685564.html
Thank You,
Dan Laden
Need assistance with an implementation?
http://www.cisco.com/go/pdihelpdesk
Daniel Laden
Level 4
Level 4
Thank You,
Dan Laden
