Cisco UCS compatibility for vSphere 6
danielcooperpps
Greetings,
I was wondering when the projected date for Cisco UCS B series servers to be certified compatible for vSphere 6 was? I was hoping a Cisco engineer or product manager could comment. I don't expect an exact date, but a rough estimate would be great for planning.
Thank you in advance!
6 Replies 6
Walter Dey
The VMware compatibility lists essentially all the B- and C-Series servers with vSphere V6 support
http://www.vmware.com/resources/compatibility/search.php
Walter.
Any update on this?   Trying to decide on whether to deploy vSphere 6.0.
Hi Kris
Interop Tool at http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
Shows now e.g. Support for VMware vSphere 6.0 for B200-M4 and UCS 2.2.3.
I didn't check the other blades, but they are definitely supported as well.
Walter.
Thanks Walter,
Cisco,
Will there be a custom Cisco image for vSphere 6.0?  If so what is the timeframe?
Saurabh Kothari
Direct link for VMware compatibility guide for Cisco hardware (in particular)
http://www.vmware.com/resources/compatibility/pdf/vi_systems_guide.pdf
-Saurabh
VMware has listed the servers as compatible, but Cisco has not:
Also, will there be a custom image soon?
