Compatibilty Matrix for UCS Manager and blade firmware
SrikanthV
what is the compatibility matrix for the newly released Cisco B bundle firmware for Spectre/meltdown.
which UCS manager will support the below blade firmware.
UCS B-Series M3 Blade Servers
3.2(3a)(Mar 2018)
3.2(2f) (Mar 2018)
3.1(3f) (Mar 2018)
UCS B-Series M4 Blade Servers (except B260, B460)
3.2(3a) (Mar 2018)
3.2(2f) (Mar 2018)
3.1(3f) (Mar 2018)
Greetings.
Yes.
See https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-manager/CLI-User-Guides/Firmware-Mgmt/3-2/b_UCSM_CLI_Firmware_Management_Guide_3_2/b_UCSM_CLI_Firmware_Management_Guide_3_2_chapter_010.html#concept_E9D7E7364D314FFE87209A3D91A0AA41
Firmware Upgrade to Cisco UCS Manager Release 3.2
Scenarios for Firmware Upgrade to Cisco UCS Manager Release 3.2
Upgrading the Infrastructure software bundle (A bundle) directly to Cisco UCS Manager Release 3.2(x) is supported from Release 2.2(8) and later releases. While upgrading from releases earlier than Release 2.2(8), you must upgrade to Release 2.2(8) or 3.1(x) first for A, B, and C bundles, and then upgrade to Release 3.2(x).
For Cisco UCS Mini, upgrading the Infrastructure software bundle (A bundle) directly to Cisco UCS Manager Release 3.2(x) is supported from Release 3.0(1) and later releases.
The following table lists the upgrade paths for various Cisco UCS Manager releases.
The 3.2(x) does have the 2.28 or 3.1x min. requirements.
Kirk...
Kirk J
Greetings.
The UCSM "A" bundle and the Blade "B" bundle cross compatibility can be viewed at: https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/CiscoUCSManager-RN-3-2.html#concept_4B24EBA51A3940EEA3AB50860D963F57
In general, for the 3.1, 3.2 releases, as long as your infrastructure is at 3.1x, then you can bump the blade bundles up to 3.2(3a) for instance.
This of course assumes, there is not some specific dependency for specific hardware support at a given UCSM "A" bundle level.
Kirk...
can we upgrade UCS manager from 2.2(6f) to 3.1x?
Greetings.
Yes.
Kirk...
Thank you Kirk!!
