default Keyring's certificate is invalid, reason: unknown
Walter Dey
After upgrade to 2.1.2a, 2 UCS domains actually came with this error.
Description: default Keyring's certificate is invalid, reason: unknown
Cause: invalid-keyring-certificate
Code: F0909
I did the procedure
FI-A# scope security
FI-A/security # scope keyring default
FI-A/security/keyring # set regenerate yes
FI-A/security/keyring* # commit
Which didn't help ?
Any advice is appreciated
Walter.
20 Replies 20
Walter Dey
Here some additional information
FI-BAL16-1-A /security # sho keyring detail
Keyring default:
    RSA key modulus: Mod2048
    Trustpoint CA:
    Cert Status: Unknown
    Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            b7:2b:15:ef:b6:67:ea:9e
        Signature Algorithm: sha1WithRSAEncryption
        Issuer: CN=FI-BAL16-1
        Validity
            Not Before: Jul 17 13:40:22 2013 GMT
            Not After : Jul 17 13:40:22 2014 GMT
        Subject: CN=FI-BAL16-1
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
thanks for the details. Got the same error and also a "dead" IOM which isn`t fixed already.
See the other post. ;-)
But on both of my FIs (which are 2.1.2a by now) i got this:
Keyring default:
    RSA key modulus: Mod1024
    Trustpoint CA:
    Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            cb:95:d4:5d:a1:4c:1d:d2
        Issuer: CN=fib-A
        Validity
            Not Before: Nov 19 11:13:11 2012 GMT
            Not After : Nov 19 11:13:11 2013 GMT
        Subject: CN=fib-A
            RSA Public Key: (1024 bit)
                Modulus (1024 bit):
It is a very interessting update....
Hello Walter / Timo,
The cert status is identified as " unknown " and hence the fault.
We are tracking this issue via CSCui06351
It will take a while to get pblished on cisco.com
Copy of release notes
Symptom:
Major fault is raised for default keyring certificate status showing as unknown.
Conditions:
When default keyring exists, the certificate status would be evaluated as unknown. This is because the default keyring certificate is self-signed certificate. The same certificate is used for https communication. The clients trying to access UCSM using https would fail to validate the certificate because it is self-signed certificate.
Workaround:
Use non default keyring for https communication. It is not recommended to use self-signed certificate for https. If Customer is using default certificate (which is not recommended), it is ok to ignore this fault. It is always recommended to use certificate signed by well known/trusted CA.
@ Walter,
Hope you are doing good. Glad to see you on CSC :-)
Padma
Hi Padma,
we are using our own certificates from a trusted CA (cert is in all browsers, with at least 2 sub-CA) on our FIs.
Next to the default-keyring. Working fine so far.
Does that mean we can safely delete the default-keyring?
And won`t get any trouble later while doing any upgrade of firmware etc.?
That is how i understand your anwser.
Can you please clearify this topic, before i will delete any default-keyring?
Thanks a lot for your help.
Timo
Hello Timo,
If you are using third party CA, you can safely delete the default ( self-signed certificate ) keyring.
Padma
Thank you for the update. I opened a TAC case on this same issue yesterday after we upgraded to 2.1(2a).
dear padramas
I got the same problem too.is there any possibitilties to clear this fault?As we donnot have any third party's cert,thanks!
Hello Qi Liu,
We can safely ignore the fault and it does not affect any functionality.
Apart from using third party cert, there is no other option to clear the fault.
Padma
Hi Padramas,
ok, we can ignore the fault, but when there will be deploy a solution to resolve the fault in UCS Manager?
regards Frank
Hello Frank,
We are actively working on it and will let update the thread when I have more information on it.
Please note this defect only applies if you have UCSM 2.1.2 for the self signed cert with cert status / reason as UNKNOWN
Padma
Hello Padma,
I really wish to know why Cisco implemented this now. In my opinion this is not relevant in a datacenter already protected enviroment, could be a simple alert, but as a fault, this is bad thing.
I'm facing some troubles with my customers to do a kvm access correctly, probably I will do a rollback of UCS version.
Padma, please let us updated about it.
Thank you.
Richard
Hi Richard,
Cisco did not intentionally implement this. The problem that you are experiencing is due to a bug and certainly was not by design. Although, as Padma pointed out, a certificate from a trusted CA, is a preferred scenario.
I can assure you that it is being closely examined.
Thanks.
-Bruce
Thanks Bruce.
I will follow this thread.
Richard.
Hello @padramas , if trying to clear the alert and regenerating a default keyring then not being able to fetch domain to log in, if that related to this same issue?
