Diff b/w Nexus 5548P and 5548UP
SJ SJ
What is the
regards.
Marc Zimmermann
Level 4
Level 4
All of the Ports in a N5548UP are "Universal Ports"
That means, that every Port can be either 1Gbps, 10Gbps or Fiber Channel (1,2,4,8Gbps).
This is the only difference.
Marc
Sent from Cisco Technical Support Android App
abbharga
Level 4
Level 4
A UP or Unified ports allow you to configure ports as  Ethernet, native Fibre Channel or Fibre Channel over Ethernet (FCoE)  ports. By default, the ports are Ethernet ports but you can change the  port mode to Fibre Channel on the following unified ports:
  • Any port on the Cisco Nexus 5548UP switch  or the Cisco Nexus 5596UP switch.
  • The  ports on the Cisco N55-M16UP expansion module that is installed in a  Cisco Nexus 5548P switch.
More details:
http://www.cisco.com/web/techdoc/dc/reference/cli/nxos/commands/l2/port.html
Comapre 5548 and 5548:
http://www.cisco.com/en/US/products/ps9670/prod_models_comparison.html
./Abhinav
