ESX Vnic does not go down when FI server uplink is disabled
We are currently testing a new infrastructure and are having this issue:
On one ucs when we disable a FI server uplink to simulate a network failure, the underlying ESX host keep the Vnic connection live and does not fail over ot the other connection.
we have this issue with only one ucs the others does not create this behavior. Failover occures normaly.
we have a network policy configures with the Action on uplink fail set to link down.
any id would help.
Stephane Beausoleil
SysAdmin senior / Équipe Virtualisation
CGI
Stephane Beausoleil
virtualisation architect
CGI
2 Accepted Solutions
Keny Perez
Level 8
Level 8
Stephan,
If I am understanding correctly, you are removing/disabling a port going from the IOM to the FI?  OR from the FI to the upstream switch?
If from the FI to the IOM = in the Chassis Discovery Policy, do you have Port Channel enabled?
If from the FI to the upstream Switch:  Is there any other uplink in the same FI?  Is there any Static Pinning applied?
-Kenny
padramas
Hello Stephane,
Is the vNICs for this host ( blade )  configured for Fabric Failover in service profile ?
If Fabric Failover is enabled for vNICs, UCSM / FI handles the network failures as the fault is not visible to the OS layer.
Padma
Keny Perez
Level 8
Level 8
Stephan,
-Kenny
padramas
Hello Stephane,
Padma
Thanks I check out the policy and it was there.
And I just found the issue.
We had a failed FI that was exchange by Cisco and after the replacment the switch was left in End-Host Mode.
So thats why the fault never showed up.
Thanks all for the good answers it did help found out the issue.
Stephane Beausoleil
CGI
Stephane Beausoleil
CGI
