How to check the firmware & drivers compatibility matrix?
Julian.Milano
I have a server called TEL1 which is running the following:
UCS B200 M4
E5-2690 v3 CPU
UCS Manager on firmware 2.2(3f)
Server firmware:
-- Adapter 1 = Cisco VIC1240 V4.0(1f)
-- BIOS B200M4.2.2.3d.0.111420141438
-- Board Controller 5.0-- CIMC Controller 2.2(3f)
From what I can see, my infrastructure is at 2.2(3f) so I cannot upgrade the CIMC/server firmware to more than what it is at right now.
Is there a matrix which shows which firmwares are compatible (between architecture and server)?
2 Accepted Solutions
If your B200-M3 is running 3.1(21e) then you are using the 2.2.8g release bundle based on this document:
Release Bundle Contents for Cisco UCS Manager, Release 2.2
ucs-b200-m3-k9-cimc.3.1.21e.bin
Your A bundle would be 2.2.3 and your B bundle would be 2.2.8. This is not a supported/tested combination. If your Infra (A Bundle) was 2.2.4 or later, this would be supported, based on Note 1 outlined in green above. If you are going to upgrade infrastructure we recommend upgrading to the latest 2.2.X train for the most feature enhancements and bug fixes.
5 Replies 5
Wes Austin
I checked the document and I'm unable to decipher if my B200 M3 server running 3.1(21e) (CICM controller) is compatible with my UCS Manager running 2.2(3f)?
I would guess that the architecture version has to be at or above the firmware version of ANY servers in the chassis?
Thanks Wes, the part I don't get is how you found this:
@Wes Austin wrote:
... then you are using the 2.2.8g release bundle based on this document:
Is there a lookup tool where you put in the current firmware versions and it spits out the bundles?
If you open that document and search for :
It only appears under the 2.2.8 bundle.
