HyperFlex HX Installer VM Deleted
maqsood ahmed
Hi Expert ,
i have a situation , our  hyperflex cluster is good , up and running ,, but we deleted the HX installer vm  accidently, we need to add some vlan's now...
pls help it's urgent.
Kirk J
As root, log into your HX connect IP via SSH, and run : hx_post_install
You should get same options as your installer provided.
It's actually only a couple of steps to manually add vlans:
  • Create vlan is UCSM
  • Add vlan to vnic template in HX org (usually one called vm-network-a )
  • Create a new 'portgroup/network' under the vswitch that carries the rest of your guestVM network traffic.
Kirk
Kirk J
Kirk
