I used to stuck in Collection Manager installation for Cisco SCE
I used to install Cisco Service Control Management Suite Collection Manager.
Before that I have to install CentOS 5.5 and then install MySQL Database.
For MySQL installation, I have to use some SQL command to complete the installation
but no configuration guide on cisco website and I have to find out how.
After 2 weeks, I can do it and I feel like I can fly.
I know somebody would stuck in the installation of MySQL like me.
I have the installation guide in my blog.
But only how to install MySQL Database for SCE and how to install SCSM Collection Manager.
See my blog at http://ciscoeasysetup.blogspot.com/
6 Replies 6
Hello Sirisak,
Do you still have the guide?  I clicked on your link for the blog post and could not find it.
I have opened a case with TAC but there is no engineer available.
David Farje
Hi David
You can see my blog post. Hope this can help you.
http://alleasysetup.blogspot.com/2011/10/most-difficult-when-install-cisco-sce.html
Sirisak.C
thank you Sirisak
but i am trying install MySQL Database for SCE i have some issues
notification:
Would you like to configure the database? (yes/no): yes
Configuring CM:RDR Database...
Enter the DB type:
1 - Oracle
2 - MySQL
3 - Sybase
4 - exit
Enter your choice: 2
Enter MySQL server host (current is localhost) :
Enter MySQL server listening port (current is 3306) :
Enter MySQL server instance id (current is apricot) :
Enter CM schema user name (current is pqb_admin) :
Enter CM schema user password (current is pqb_admin) :
Do you want to test the DB connection? (yes/no): yes
FAIL:DB is not running
DB connection failed.
i show you my configuration DB MySQL
[root@sersce install-scripts]# mysql -u pqb_admin -p
Enter password:
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 4
Server version: 5.0.92-community-log MySQL Community Edition (GPL)
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> show databases;
| Database           |
| information_schema |
| apricot            |
| test               |
3 rows in set (0.00 sec)
so you see on my log the DB MySQL doesn't connected with CM
what i can do it for resolve my problem ?
You can try this step.
Login to mysql then follow by these command
host#mysql -u root
mysql> set password for 'root'@'localhost' = password('your_password');
mysql> set password for 'root'@'127.0.0.1' = password('your_password');
mysql> create database apricot;
mysql> set password for 'pqb_admin'@'localhost' = password('pqb_admin');
mysql> set password for 'pqb_admin'@'127.0.0.1' = password('pqb_admin');
i am trying do it those steps :
ERROR 1133 (42000): Can't find any matching row in the user table
Hi Itap.
     I would like to recommend you to follow my step by following link.
PS. (just do the fresh installation)
