Issues with UCS Powershell 2.1.5.6
PranavGupta9527
Hello Team,
I am facing issues with the UCS Powershell tool. As soon as I type in the command Connect-Ucs -Name <UCSM IP> the tool hangs up. It doesn't ask me for credentials. I am attaching the screenshot below.
Unable to connect to Cisco UCS and hangs up. No dialog box comes for credentialsUnable to connect to Cisco UCS and hangs up. No dialog box comes for credentials
Kindly assist me with this issue.
Power Shell Version - 2.5.1.6
UCSM Version - 4.0.4h
OS - Windows Server 2016
Pranav Gupta
Kirk J
I have also had a lot of issues with the later power tools giving errors on auth protocol's not supported, etc.
You might want to try posting in https://community.cisco.com/t5/cisco-developed-ucs-integrations/bd-p/4354j-disc-cisco-dev-ucs-integ   and see if you get faster response.
Kirk..
Hi Kirk,
I think its not Just UCS PowerCli but VMware PowerCli is also working really slow. I tried to import the module and tried to run the commands on PowerShell however the issue remained the same.
Pranav
