KVM error
George Thomas
Level 11
Level 11
Running CIMC 2.0.3i, KVM is giving the error, network connection reset. CIMC 1.5 seemed to work fine.
Seeing the following errors in Java console:
Missing Application-Name manifest attribute for: https://10.192.160.9:443/software/avctNuova.jar
KVM/VM Client Version: 5.04.02 (Build 24)
May 26, 2015 10:32:27 AM java.util.prefs.WindowsPreferences <init>
WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at root 0x80000002. Windows RegCreateKeyEx(...) returned error code 5.
replace numpad
replace numpad
** Max Size: W = 1600 H = 755
** Window Pref Size: W = 1040 H = 828
JNLPClassLoader: Finding library VMAPI_DLL.dll
JNLPClassLoader: Finding library jawt.dll
JNLPClassLoader: Finding library avctKVMIO.dll
ProtocolAPCP.receieveSessionSetup : v1.2 APCP = true
Try again with the reduced mode protocol list
Already tried the reduced mode protocol list, quitting
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(Unknown Source)
at java.io.DataInputStream.read(Unknown Source)
at com.avocent.protocol.apcp.ProtocolAPCP.receiveSessionSetup(Unknown Source)
at com.avocent.protocol.apcp.ProtocolAPCP.getAvspSocket(Unknown Source)
at com.avocent.protocol.apcp.ProtocolAPCP.getAvspPrimarySocket(Unknown Source)
at com.avocent.protocol.avsp.AvspKvmSession.connectToPort(Unknown Source)
at com.avocent.api.viewer.RPAPIClientViewer.sendConnectRequestToServer(Unknown Source)
at com.avocent.api.viewer.RPAPIClientViewer.openViewerClient(Unknown Source)
at com.avocent.app.kvm.DefaultViewerMainController.startSession(Unknown Source)
at com.avocent.app.kvm.DefaultViewerMainController.startApp(Unknown Source)
at com.avocent.nuova.kvm.CiscoViewerMainController.startApp(Unknown Source)
at com.avocent.nuova.kvm.Main.runApp(Unknown Source)
at com.avocent.nuova.kvm.Main.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.sun.javaws.Launcher.executeApplication(Unknown Source)
at com.sun.javaws.Launcher.executeMainClass(Unknown Source)
at com.sun.javaws.Launcher.doLaunchApp(Unknown Source)
at com.sun.javaws.Launcher.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
CoreSessionListener : connection failed
in CoreSessionListner : fireOnSessionStateChanged
 KVM session state SESSION_FAILED
Please rate useful posts.
5 Replies 5
Keny Perez
Level 11
Level 11
What is the current Java version in use?
Does this happen on different PCs?
-Kenny
I am having java version 8 update 51.
It is working in other pc's not in mine. what could be the problem?
Babu
Can you tell me your system configuration CIMC release notes are different for different PC's, I need to check if your system requirements meet the release notes specs.
Hi Farhan,
when you say system configuration, are you talking about OS and java version?
-Babu
Yes, I am talking about both. Please see the document below in the link to help you upgrade firmware:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/cli/config/guide/1-4-1/b_Cisco_UCS_C-Series_CLI_Configuration_Guide_141/b_Cisco_UCS_C-Series_CLI_Configuration_Guide_141_chapter_01101.html
There is other link below for CIMC relase notes so you can check if the firmware version is compatible with OS you are using or not:-
Also, check the release notes below for compatibility:-
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/OL-28995-01.html
If this doesn't solve your problem,  open tac case, www.cisco.com/tac
