Looking for a list with sysObjectIDs for Cisco Fabric Interconnects
epessers
Is there somewhere a list with the sysObjectID values used for Fabric interconnets etc.
I.e., is there an equivalent document for sysObjectID OIDs in the 1.3.6.1.4.1.9.12 range (similar to the CISCO-PRODUCT-MIB for the 1.3.6.1.4.1.9.1 range)?
This would help us in setting up our discovery and polling engines for managing UCS environments.
Qiese Dides
I was able to find information about the OID’s we use for CPU, memory, etc and I have copied the documentation below:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/mib/b-series/b_UCS_MIBRef/b_UCS_MIBRef_chapter_0100.html
Also,
I have included a link for the MIB installation which should prove useful:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/mib/b-series/b_UCS_MIBRef/UCS_MIBRef_chapter_011.html
Also, this link is included in the above product documentation, but I figured I'd include it here as well:
ftp://ftp.cisco.com/pub/mibs/supportlists/ucs/ucs-manager-supportlist.html
With this link, you should be able to download all the MIB files for UCSM. If you have any questions, please feel free to let me know.
Here are the OID's that customers usually look for,
Memory statistics
CISCO-UNIFIED-COMPUTING-MEMORY-MIB
.1.3.6.1.4.1.9.9.719.1.30 is the parent OID where the key statistics reside.
Ethernet
CISCO-UNIFIED-COMPUTING-ETHER-MIB
.1.3.6.1.4.1.9.9.719.1.16 is the parent OID where the key statistics reside.
Processor
CISCO-UNIFIED-COMPUTING-PROCESSOR-MIB
.1.3.6.1.4.1.9.9.719.1.41 is the parent OID where the key statistics reside.
Hopefully this information is helpful. There are several other OID's at the following site which you might also be interested in:
However, I can’t provide you with those specific OID’s of the Fabric Interconect, but I can tell you how to get them, or how to get the info you are looking for.
In order to get those specifics, you can load the MIBs into whatever program you are using, and walk for a specifc mib file. You should be able to expand the ‘enterprise’ mib and see all the possible options you can walk. Hopefully this clears things up as I am unable to give you spefic OIDs, I can only provide the MIBs.
Hi Qiese Dides,
 excellent info, +5 for that!!!!
Glad it could help :).
Qiese Dides
