Mellanox cable (P/N# MC220731V-030) on Cisco Nexus 5672UP QSFP+ 40GB port
ggmathews
We are in the process of connecting two different switches (One is Arista Switch and the other one is a Cisco Nexus 5672UP) on two different networks between two different labs on a single floor using Mellanox cable (P/N# MC220731V-030).  As we connected one end of the Mellanox cable to the QSFP+ port on the Cisco Nexus 5672UP, and we did not see any visual signs that the cable is connected to switch. When we looked it on the switch from CLI, it shows the following:
# sh logging log | in 2/1
2016 Dec 18 17:54:18  %ETHPORT-5-IF_HARDWARE: Interface Ethernet2/1, hardware type changed to No-Transceiver
2016 Dec 18 17:54:21  %ETHPORT-5-IF_DOWN_NONE: Interface Ethernet2/1 is down (Transceiver Absent)
2017 Apr 27 14:25:24  %ETHPORT-3-IF_NON_CISCO_TRANSCEIVER: Non-Cisco transceiver on interface Ethernet2/1 is detected
2017 Apr 27 14:25:24  %ETHPORT-3-IF_SFP_ERROR: Interface Ethernet2/1, invalid SFP detected
2017 Apr 27 14:25:24  %ETHPORT-5-IF_DOWN_FCOT_VENDOR_NOT_SUPPORTED: Interface Ethernet2/1 is down (Error disabled - Fcot vendor not supported)
# sh int eth2/1 transceiver details
Ethernet2/1
transceiver is present
type is QSFP Unknown Type-(unknown)
name is Mellanox
part number is MC220731V-030
revision is A1
serial number is DW401600164
nominal bitrate is 14100 MBit/sec
Link length supported for copper is 30 m
cisco id is --
cisco extended id number is 0
DOM is not supported
So the question is, how to configure this Mellanox cable with the Cisco Nexus 5672UP on the QSFP+ port to connect between two different switches (Cisco Nexus 5672UP and Arita) on two different network?
Gigi Mathew
0 Replies 0
