Problem accessing remotely to a UCS 6120XP
altorres75
Hello,  I have 2 ucs 6120XP clustered and I cannot access them remotely.  Routing is OK, local ping is OK, but when I try to ping the virtual IP address or the management ip for each unit there is no response.
Any hints?
Alex Torres
Eric Rose
Might be a silly question but is the out of band management port connected in the same vlan?
Eric Rose
hehehe, I mistakenly clicked correct answer.
Yes, they are in the same vlan and subnet.  I have 2 SVIs, the one in the same vlan and subnet responds ok, as it is local, but when I ping from the switch using as source the other SVI I get no response.
ok, problem solved.
Great to hear.
Happy Holidays!
