Remove Nexus 5548 old licences
Dean Brandt
I have recently acquired a 5548 and simply want to use it as a L2 device with UCS servers connected to it.
It has the following licences attached:
N5k-PDC-01# sh license
12.lic:
SERVER this_host ANY
VENDOR cisco
INCREMENT LAN_BASE_SERVICES_PKG cisco 1.0 permanent uncounted \
VENDOR_STRING=<LIC_SOURCE>MDS_SWIFT</LIC_SOURCE><SKU>N5K-BASE-EVAL</SKU> \
HOSTID=VDH=SSI18270BBB \
NOTICE="<LicFileID>20180326044023850</LicFileID><LicLineID>1</LicLineID> \
<PAK></PAK>" SIGN=AED5190CF81A
abc.lic:
VENDOR cisco
INCREMENT LAN_ENTERPRISE_SERVICES_PKG cisco 1.0 24-jun-2018 uncounted \
VENDOR_STRING=<LIC_SOURCE>MDS_SWIFT</LIC_SOURCE><SKU>N5K-ENT-EVAL</SKU> \
NOTICE="<LicFileID>20180326042852954</LicFileID><LicLineID>1</LicLineID> \
<PAK></PAK>" SIGN=7922519EF2D6
A list of bootflash: doesn't show these license files though
How do i remove and ensure any licensing asscociated with them isn't operating?
Many thanks for your help here. The only thing the doc doesnt make clear is that after you check each licence you need to do a "no feature <insert feature>" from config mode
