10-06-2014 05:02 AM - edited 03-01-2019 11:52 AM
Hello
We have Cisci UCS blade servers B420 M3 serial : FCH1710J7JP
and the Fabric Interconnect : UCS-FI-6248UP
I need to know if those product are vulnerable for ShellShock
If they are vulnerable witch patch I need to install ?
Solved! Go to Solution.
10-06-2014 09:04 AM
Hi Konstantin-
Yep, your Fabric Interconnect is, and there is no patch released yet.
Here is the bug: https://tools.cisco.com/bugsearch/bug/CSCur01379
Here is a link to the Security Advisory: http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20140926-bash
DJ
10-12-2014 03:27 PM
10-06-2014 09:04 AM
Hi Konstantin-
DJ
10-06-2014 11:57 PM
Do you know when the update suppose to release ?
10-07-2014 07:03 AM
Hi Konstantin-
I do not. Keep an eye on the bug that I referenced and it should be updated.
DJ
10-09-2014 06:56 AM
They expect to have an update in the week starting 10/13/14.
10-12-2014 03:27 PM
10-18-2014 10:12 PM
I have 2.2(1d)
I don't see that version on the list
does this version is fine - not need update ?
10-19-2014 05:30 AM
All releases starting with the the first release 1.0(1e) are vulnerable.
You have 2.2(1b) so you have to upgrade to 2.2(1f) or any other version above that such as 2.2(2e), 2.2(3b) or 3.0(1d).....
