Software Raid Key for 2 HDDs
Grace Zhu
Do anybody know if a software raid key is needed for a 2 HDD raid 1 or 0, in a embedded raid controller ?
Yes you are right, what I was trying to say is that by default the software raid (embedded ) may supports raid 0,1 and 10 but you have to meet the hard disk requirements.  For the c220 m3 server you don't required a key for raid 0 or raid 1, but you need to make sure you are using SATA drives, if you are using SAS drives then you need the key.
Manuel Velasco
Hi Grace, In most of the ucs servers the embedded controller supports raid 0 1 and 10 by default and you will only support a key for raid 5 and to support SAS drives. What is the model of your server?
C220 M3.
I though for 2 HDD,  only can be Raid 0 or Raid 1, so will not need the software license Key, right?
Thanks!
