UCS C210 m2 Fan Speed issues
robertkruk
one of my servers has the fans going very fast at 6K to 8K.
my second server of similar config is at a normal fan speed around 2K.
i have had this happen in the past and i think i updated the firmware which seemed to fix. but it seems to have reoccurred.
i have restarted the server and the fans are still going fast.
both servers are running BIOS
C200.1.4.1.0 (Build Date: 07/13/2011)
CIMC
update:
I have just also just now tested to compleatly shutting down the server and rebooting which seems to have helped.
except now only the PSU fans are going around 5K
the system fans seem to have stablised back to normal 2-3K range.
my other UCS server PSU fans are running at 2 to 2.5K.
Tempreature is not an issue, they are both running approx same temps.
...and both are under minimal load
any ideas as to why the PSU fans are running high?
Hi Robert,
I guess I should also point out that your two servers have two different versions of power supplies in them which explains the differences in steady state PSU fan speeds even after working around the bug I think one of the servers may have run into.  ucs-c200 has older PSUs that have two inline fans so the fans can run at a lower speeds to maintain the required temperature.  ucs-c210-m2 has newer PSUs that have only a single fan in them so they have to run the fans at higher speeds to maintain the required temperatures.
Mike
13 Replies 13
padramas
Hello Robert,
How long the problematic server has been in use ?
SSH into CIMC and please provide us the following output
scope chassis
show psu detail
show pci-adapter detail
exit
scope sensor
show fan
show temperature
Padma
ucs-c210-m2# scope chassis
ucs-c210-m2 /chassis # show psu detail
Name PSU1:
    In. Power (Watts): 89
    Out. Power (Watts): 650
    Firmware : 00.01.04
    Status : Present
    Product ID : R2X0-PSU2-650W-SB
Name PSU2:
    In. Power (Watts): 107
    Firmware : 00.01.04
    Status : Present
ucs-c210-m2 /chassis # show pci-adapter detail
Name PCIe Adapter1:
    Slot: 5
    Vendor ID: 0x1000
    Device ID: 0x0079
    Product Name : LSI 9261-8i MegaRAID SAS HBA
ucs-c210-m2 /chassis # exit
ucs-c210-m2# scope sensor
ucs-c210-m2 /sensor # show fan
Name                 Sensor Status        Reading    Units      Min. Warning    Max. Warning    Min. Failure    Max. Failure
PSU1_FAN_1           Normal               5248       RPM        N/A             N/A             N/A             N/A
PSU2_FAN_1           Normal               4992       RPM        N/A             N/A             N/A             N/A
W793_FAN1_TACH1      Normal               2300       RPM        N/A             N/A             800             N/A
W793_FAN1_TACH2      Normal               2700       RPM        N/A             N/A             800             N/A
W793_FAN2_TACH1      Normal               2400       RPM        N/A             N/A             800             N/A
W793_FAN2_TACH2      Normal               2800       RPM        N/A             N/A             800             N/A
W793_FAN3_TACH1      Normal               2400       RPM        N/A             N/A             800             N/A
W793_FAN3_TACH2      Normal               2500       RPM        N/A             N/A             800             N/A
ucs-c210-m2 /sensor # show temperature
IOH_TEMP_SENS             Normal         39.0       C          N/A          80.0         N/A          85.0
P2_TEMP_SENS              Normal         17.5       C          N/A          72.0         N/A          77.0
P1_TEMP_SENS              Normal         16.0       C          N/A          72.0         N/A          77.0
DDR3_P2_D1_TMP            Normal         25.0       C          N/A          68.0         N/A          70.0
DDR3_P2_D2_TMP            Normal         25.0       C          N/A          68.0         N/A          70.0
DDR3_P2_E1_TMP            Normal         23.0       C          N/A          68.0         N/A          70.0
DDR3_P2_E2_TMP            Normal         23.0       C          N/A          68.0         N/A          70.0
DDR3_P2_F1_TMP            Normal         23.0       C          N/A          68.0         N/A          70.0
DDR3_P2_F2_TMP            Normal         24.0       C          N/A          68.0         N/A          70.0
DDR3_P1_A1_TMP            Normal         28.0       C          N/A          68.0         N/A          70.0
DDR3_P1_A2_TMP            Normal         27.0       C          N/A          68.0         N/A          70.0
DDR3_P1_B1_TMP            Normal         29.0       C          N/A          68.0         N/A          70.0
DDR3_P1_B2_TMP            Normal         28.0       C          N/A          68.0         N/A          70.0
DDR3_P1_C1_TMP            Normal         27.0       C          N/A          68.0         N/A          70.0
DDR3_P1_C2_TMP            Normal         28.0       C          N/A          68.0         N/A          70.0
PSU1_TEMP_1               Normal         41.0       C          N/A          60.0         N/A          65.0
PSU2_TEMP_1               Normal         40.0       C          N/A          60.0         N/A          65.0
FP_AMBIENT_TEMP           Normal         24.0       C          N/A          40.0         N/A          45.0
This is from my other server for comparison (the one with no issue)
ucs-c200# scope chassis
ucs-c200 /chassis # show psu detail
Name PSU1:
    In. Power (Watts): 82
    Firmware : R0E
    Status : Present
    Product ID : SUNNY651AM
Name PSU2:
    In. Power (Watts): 97
    Firmware : R0E
    Status : Present
ucs-c200 /chassis # show pci-adapter detail
Name PCIe Adapter1:
    Slot: 2
    Vendor ID: 0x8086
    Device ID: 0x10e8
    Product Name : Intel E1G44ET 1 Gbps 4 port NIC
Name PCIe Adapter2:
    Slot: 5
    Vendor ID: 0x1000
    Device ID: 0x0079
ucs-c200 /chassis # exit
ucs-c200# scope sensor
ucs-c200 /sensor # show fan
PSU1_FAN_1           Normal               2176       RPM        N/A             N/A             N/A             N/A
PSU2_FAN_1           Normal               2560       RPM        N/A             N/A             N/A             N/A
W793_FAN1_TACH2      Normal               2400       RPM        N/A             N/A             800             N/A
W793_FAN2_TACH1      Normal               2300       RPM        N/A             N/A             800             N/A
W793_FAN2_TACH2      Normal               2600       RPM        N/A             N/A             800             N/A
W793_FAN3_TACH1      Normal               2500       RPM        N/A             N/A             800             N/A
W793_FAN3_TACH2      Normal               2600       RPM        N/A             N/A             800             N/A
ucs-c200 /sensor # show temperature
IOH_TEMP_SENS             Normal         38.0       C          N/A          80.0         N/A          85.0
P2_TEMP_SENS              Normal         16.5       C          N/A          66.0         N/A          74.0
P1_TEMP_SENS              Normal         15.5       C          N/A          66.0         N/A          74.0
DDR3_P2_D1_TMP            Normal         26.0       C          N/A          68.0         N/A          70.0
DDR3_P2_E1_TMP            Normal         24.0       C          N/A          68.0         N/A          70.0
DDR3_P2_E2_TMP            Normal         25.0       C          N/A          68.0         N/A          70.0
DDR3_P1_A1_TMP            Normal         27.0       C          N/A          68.0         N/A          70.0
DDR3_P1_B1_TMP            Normal         27.0       C          N/A          68.0         N/A          70.0
DDR3_P1_B2_TMP            Normal         27.0       C          N/A          68.0         N/A          70.0
PSU1_TEMP_1               Normal         37.0       C          N/A          60.0         N/A          65.0
PSU2_TEMP_1               Normal         38.0       C          N/A          60.0         N/A          65.0
FP_AMBIENT_TEMP           Normal         25.0       C          N/A          40.0         N/A          45.0
Robert,
PSU model R2X0-PSU2-650W-SB can cause some known issues and is documented here
http://www.cisco.com/en/US/ts/fn/634/fn63425.html
You can request for repalcement PSUs using the above the link.
Padma
I have 4 C240's where the power supply fans on all four are not working/spinning; is this normal?  the nodes are about 1 year old.
kg6itcraig
We had issues like this through the 1.4(3m) code levels.
Craig
My UCS Blog http://realworlducs.com
so am i not at the latest firmware?
I can only see 1.4(2) in the download area
Hi Robert,
I believe Craig was referring to B-series firmware version 1.4(3m).
For the C-series this is likely due to a bug in the processor temperatue sensing code of CIMC, CSCtu08709.  The fix will be in the next release of CIMC which confusingly will most probably be numbered 1.4(3something) and is due either some time late this month or early next month.  Unfortunately software release schedules are never set in stone and are difficult to predict.
For full confirmation I would suggest collecting a tech support the next time the server exhibits the problem before trying to workaround it and opening a TAC case.  You could try collecting that now and opening a TAC case but there is a chance that the logs have wrapped and evidence of the issue is no longer available.
Mike
Thats cool.
It was bugging me when all the fans were going fast, but after shutdown its just the PSU so the audible fan noise is not noticable.
I look forward to the new firmware patch when it is available.
Hi Robert,
Mike
ahh yes that would explain the PSU fans.  But they still seem a little high (RPMs) considering the temperature?
system fans have speed up again
edit: actually its on the other UCS server. Just the system fans are going nuts.
I have opened a TAC
Robert,
Did you got a chance to replace the PSUs ?
Padma
