05-16-2014 09:22 PM - edited 03-01-2019 11:40 AM
Hi-
I'm running ESXi 5.5 on one SD card in FlexFlash, but would like to add a 2nd one to complete the raid for safety.
Does the card need to be formatted by the BIOS setup in order to work? I tried just inserting another 16GB card, but web interface throws an error that the sizes do not match. Both are 16GB, but 1 is class 10, and the other is a newer class 1 ultra fast card.
thanks for any advice.
05-16-2014 11:40 PM
dagerson,
First thing to clarify... Even though CIMC may say RAID degraded with one card only, the 2 cards make a mirror but do not work like RAID cause if one card fails and you install a new one, the array is not rebuilt like disks do (FYI)
Are both cards Cisco branded?
You dont need to format the cards for them to make the mirror, yuo need to access the SCU (either from the card itself by enabling the partition or downloading it from cisco.com) and once inside of it, hit on the icon that synchs up the cards.
-Rate ALL helpful answers.
Kenny
05-23-2014 05:59 AM
Did I answer your question? If so, please mark it as such for future users to know you found what you were looking for...
-Kenny
06-10-2014 12:57 PM
Following document will be helpful
http://www.cisco.com/c/dam/en/us/solutions/collateral/data-center-virtualization/unified-computing/whitepaper_C11-718938.pdf
Shahzad
07-23-2014 06:11 AM
@sarain
The doc you linked says "If the SD card is blank, all partitions will be marked with an error":I tried with a blanked one (not Cisco branded) but it doesn't show any partition, as if they were not activated.
Must the SDCard be purchased from Cisco?
Thanks.
07-23-2014 07:05 AM
It must, we do NOT support third party SD cards.
-Kenny
07-23-2014 09:15 AM
@kenperez
Thanks for your reply.
What do you mean with "we do not support"? Are third party SD cards not supported in case of trouble or do they simply not work?
07-23-2014 09:20 AM
"unsupported" and "do not work" are 2 different things, if you install a third party card and it does not work, the first thing TAC will tell you is that you need a Cisco branded SD card
-Kenny
07-23-2014 10:16 AM
Thanks for your reply @kenperez
In case of emergency situation (like original Cisco SD Card broken and no spare part), does anyone know if there is a way to create partitions in a third party SD card?
Thanks a lot
07-23-2014 10:49 AM
If you have 2 SD cards in the server, you can mirror them... low % of chances that both will go bad before you can get a new one
-Kenny
