UCS in the lab
S891
Level 2
Level 2
Hi everyone,
I am trying to build a UCS lab environment and need need some help with the build. I will probably buy it from third party reseller. I need minimum basic components.
I would really appreciare if someone could help me build the required components for UCS anf FI. I already have dual N5Ks.
Chassis:  5108?
FI: 2 x 6100  ?
IOM: 2 x 2100 ? Dual
Blades model: 2 x B200 ?
Blade count: 2
Core Count: ?
Processor: ?
RAM: ?
Drives: ?
I will just run 5 to 6 VMs. I dont need high processor and RAM.
This is just for lab setup so I don’t need new equipment. I will get old even if it is close to EOL/EOS.
Tyler P
Do you want your lab to be running on new firmware 3.1xx + ? or are you cool with leaving at 2.2xx?
That changes a lot with what hardware is compatible.
I am ok with running 2.2x in the lab setup.
cisco ucs emulator?
Hi, Fawad-Alam
I would just recommend getting set up with a entry level Gen2 set up.
6100 FIs
5108 with 2104s or 2204s
2 x B200-M2 basic conf, 2 x 6core, maybe 48gb ram and a couple 146gb 10k drives.
It wouldn't need to be a rocket ship. If you would like to discuss further please email me and we could try and work with your budget. tpederson@vibrant.com
