UCS Manager Issue
i have problem with Cisco UCS manager, after logging in UCS Manager i get an error.
Cristobal,
This is definitely a bug cause UCSM is not doing what it is supposed to and the only bug that really fits (based on the version you are running) is  https://tools.cisco.com/bugsearch/bug/CSCum95854/?reffering_site=dumpcr ; and seems to be fixed in the latest versions...  2.2.2c; 2.2.3a; 2.5.1a; 3.0.2c (UCS Mini)
Advice is to contact TAC for further assistance (if required).
-Kenny
9 Replies 9
Charles Hill
Take a look at bug CSCta94641
CSCta94641
Problem Description:
When waking up from sleep, UCSM GUI will detect an event sequencing error and display the error: "Event Sequencing is skewed", as the JRE doesn't have a sleep detection mechanism.
Workaround:
Always shutdown UCSM GUI before putting your computer to sleep.
Hope this helps,
Please rate helpful posts.
Thanks.
Hi Charles,
I tested it with windows 2003 server and 2008 virtual machines, these will not enter sleep mode and the problem persists.
If you close the gui and retry, is it successful?
Here is a troubleshooting guide.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ts/guide/UCSTroubleshooting.html
However, it references that same issue with going to sleep.
Thanks!
What UCSM version?
Can you reproduce at will? If yes, what steps do you take to make this happen?
Do you really get logged out? what happens if you just try to close the pop-up window? are you kicked out?
Any recent change in the firmware or Java version?
Does this happen when connecting through a PC?
-Kenny
Hi Keny,
What UCSM version?
-Cisco UCS Manager - 2.0(1s)
- Yes, Open the UCS manager
-I always off, close the window and closes all
-1.6
-Yes. really all host including laptop, pc, vm.
- See more at: https://supportforums.cisco.com/discussion/12535226/ucs-manager-issue#sthash.PBGJWxaO.dpuf
Cristobal,
-Kenny
Hi keny,
The problem is resolved with a update to version 2.2(3g).
Thanks!
Glad to help Sir!
-Kenny
