Upgrade CIMC
markgaring1989
Is it ok to upgrade the cimc of cisco from 3.0(3a) to 4.1(2a) or i just need to upgrade it to 3.0(4a)?
Thank you
Thank you Leo for pointing to my post
Those iso files are direct downloads from cisco.com. You do not want any application to make it a iso files. See below post.
https://mrncciew.com/2019/09/06/cimc-upgrade-8540-5520-wlc/
What hardware model is it?
Rasika
*** Pls rate all useful responses ***
5 Replies 5
Leo Laohoo
You can go "straight" upgrade from 3.X to 4.X.
NOTE:
If you read the Release Notes, the procedure to upgrade the CIMC firmware is incomplete and confusing.  @Rasika Nayanajith has knocked up a detailed step-by-step process (LINK) that I find very useful.
WARNING
CIMC upgrade can take, on average, 70 minutes.  During this time, the server is off.
Thank you for this guide, i will try it now.
Im having an error when it say's he is copying some files error code 906....i used rufus application to make a bootable ISO...the firmware i install is 4.0(2a)...any work around for the problem?
Thank you
Rasika
Thank you for this i've successfully upgraded the cimc version.
the hardware model is C240 M4
