Cisco UCS not "seeing" 2 Chassis
ksarin123_2
Folks -
I am running UCS 2.0(1w) and have a total of 4 chassis, with 2 of the chassis not showing up in UCS Mgr. The 2 chassis that are not showing up have a single full width blade (which does not have any template assigned yet). All the server ports (total of 16) on both of the fabric interconnects are showing as up. Each chassis has 4 links (from each IOM) to the FI. Any idea why the 2 chassis are not showing up?
Thanks!
chrisb2
There is a couple of things you can check.
First check the "decommissioned" tab and see if the chassis show up there.
If the chassis are not there try setting the chassis discovery policy to 1 link and see if it shows up then. You may need to disable/enable the server ports.
If it's still not showing up try using one of the cables from the working chassis.
chrisb2
Thank you chrisb2!  Decommissioned tab fixed my problem.
