upgrade hardware in CISCO UCS
andyblada1
Hello All,
I am planning to upgrade my environment from old existing hardware to new hardware.
Existing Equipments
Two FI 6248 UP
One Chassis UCSB-5108-AC2
Two Chassis N20-C6508
Six UCS-IOM-2208XP
21 UCSB-B200-M3 blade servers.
I want to replace above with below hardware
Two FI 6248 UP
Three Chassis UCSB-5108-AC2
Six UCS-IOM-2208XP
21 UCSB-B200-M4 blade servers.
What will be the approach should i follow? With minimal downtime
Qiese Dides
Hi Andy,
This link gives you step by step instructions on how to remove and replace each of those components.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/hw/chassis-install-guide/ucs5108_install/ucs5108_install_chapter_011.html
Hope this helps,
Let me know if you have any other questions.
Qiese Dides
Hi Qiese,
Thank you for your reply! i'll go through the link and let u know if any help needed.
In the meanwhile, just wanted to know. Can i use my existing license of existing 6248 FI on new 6248 FI??? and how ?
