vnic bandwidth question
dave.clark-SGP
I have a blade with a VIC 1240. I can attach 6 10GB nics to it for 60GB bandwidth. My question is, If I only connect 2 nic to it will use 30GB bandwidth each or do I have to define all 6 to utilize all the bandwidth?
Thx
Walter Dey
Hi David
Before you consider the virtualized part of the adaptor, you should consider the hardware connectivity.
Following configurations are possible (lets assume B200-M3)
1) VIC-1240 (MLOM) plus 2204 (IOM)
2) VIC-1240 (MLOM) plus 2208 (IOM)
3) VIC-1240 (MLOM) + Extender plus 2204 (IOM)
4) VIC-1240 (MLOM) + Extender plus 2208 (IOM)
the resulting bandwith (adpator - chassis backplane - IOM) are the following
1) dual 1 x 10G
2) dual 2 x 10G
3) dual 2 x 10G
4) dual 4 x 10G
If you now create n x vnics and m x vhba in your service profile, they are multiplexed over the available physical bandwith above; so you will have oversubscription !
Lets assume you have a ESXi server with 2 vnics, one connected to fabric a, the other to fabric b. Lets also assume you have configuration 2) or 3); then your vcenter shows a vnic of 20G
You control the oversubscription of the adaptor configuration; eventually, you could also create QoS policy and attach it to a vnic.
