configuration example for fractional T1
cjrchoi11
I have a module VWIC2-2MFT-T1/E1 in 2811 and will purchase a signle fractional T1 from carrier with 10 channels to data and another 10 to voice.
Can I have a configuration example to achieve this to cover data and voice both in single T1 interface?
Thanks in advance,
5 Replies 5
card-type t1 0
controller t1 0/0
pri-group time 1-10,23
linecode b8zs
framing esf
clock source line
network-clock-select 1 t1 0/0
That's the PRI part, at least.
Can this fractional T1 be managed with MGCP in CUCM 6.x?
Julien
Yes.
Hi Julien,
It can be - but you have to change service parameters to make sure that CUCM sees the other channels as out of service. There's a specific service parameter just for this.
They are these values - "Change B-Channel Maintenance Status 1" and so on. The help information for them can guide you on the syntax.
hth,
nick
Thanks guys,
I figured out how to configure both type(data and voice) into single T1 interface. my case channel 1-10 to voice and 11-20 to data.
controller t1 0/0
linecode b8zs
framing esf
channel-group 0 time 11-20
John
