Showing results forĀ
Search instead forĀ
Did you mean:Ā
Alarm AL del of VWIC2-1MFT-T1/E1 is always switch on
supernova14
Good morning
I want to configure the Cisco 2811 E1 interface (VWIC2-1MFT-T1/E1) but i have a problem with the Alarm DEL (AL) witch it is always in yellow color.
The AL del is switch on just after i enter  the first command router(config)# card type E1 0 1
the command sh controller E1 gives the result below
R-VOIP# sh controller E1
E1 0/1/0 is down.
  Applique type is Channelized E1 - balanced
  Cablelength is Unknown
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
  alarm-trigger is not set
  Version info Firmware: 20080918, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (85 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 85 Unavail Secs
E1 0/1/1 is down.
  Data in current interval (88 seconds elapsed):
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 89 Unavail Secs
the command sh run gives the result below
R-VOIP# sh run
Building configuration...
Current configuration : 3010 bytes
version 12.4
hostname R-VOIP
boot-start-marker
boot-end-marker
card type e1 0 1
logging message-counter syslog
enable secret 5 $1$WjDK$Bxgi6CV6QYaMYIBBxpLzb/
no aaa new-model
no network-clock-participate wic 1
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.0.0.1 10.0.0.10
ip dhcp pool MyPhones
   network 10.0.0.0 255.255.255.0
   option 150 ip 10.0.0.1
ip dhcp pool myphonesno
no ipv6 cef
stcapp ccm-group 1
stcapp
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
fax protocol cisco
h323
  call start slow
voice-card 0
archive
log config
  hidekeys
controller E1 0/1/0
controller E1 0/1/1
interface FastEthernet0/0
ip address 192.168.3.80 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clock rate 125000
interface Serial0/0/1
no ip address
shutdown
clock rate 125000
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
Can you tell me if this is normal or not?
I need to configure the Cisco 2811 E1 interface (VWIC2-1MFT-T1/E1) with the E1 line of Telecom provider
Another question, the router must be connected to the modem or just plug it directly to the E1 line of the Telecom provider ?
The interface VWIC2-1MFT-T1/E1 do the same functions like a modem or not?
thank a lot
paolo bevilacqua
You plug interface directly into E1 from telco.
At that point, if cabled correctly, the alarm will go away.
For further questions use IP telephony forum
