02-13-2012 08:45 AM
I'm trying to block incoming blocked/unknown/anonymous callers over a sip trunk? I've creaed a translation rule and applied it:
voice translation-rule 5000
rule 1 reject /^$/
voice translation-profile CallBlock5000
translate calling 5000
dial-peer voice xxxx voip
call-block translation-profile incoming CallBlock5000
call-block disconnect-cause incoming invalid-number
To try it out, I'm dialing (from a normal/off network cell and landline) *67 and then the number. This does not work; only if I match the exact number I'm calling from, then it does get blocked.
When I show sip calls during the *67 call I see the calling number is blank.
Calling Number :
When I show sip calls during the regular call, I see the proper Calling Number.
As I understand it, with Call Manager and phones running SCCP, I cannot enable/use anonymous call blocking; so I do have to enforce the call blocking policy at this gateway device (UC520).
I'm very new to Cisco voice, so sorry I'f I'm missing something obvious. Thanks in advance!
02-14-2012 10:20 AM
What is the anonymization method used by your isp provider?
In SIP you can set CLIR in various ways:
- set the display info of from header to anonymous but not the user part;
- set the user part of from to anonymous but not domain;
- use the form anonymous@anonymous.invalid in the from header;
- set the privacy option in Remote Party ID;
- set the option Privacy in P-Asserter-ID;
- remove identity omitting the number;
etc.
Can you add the output of debug ccsip messages?
In this way we can find what methods are used.
In the meantime you can test this rule:
rule 1 reject /^.*/ type reserved
Regards.
02-14-2012 02:01 PM
Thanks, I tried the rule--still private gets through.
*Feb 14 21:52:37.457: //394/0B18CF2B8382/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 207.2.123.180:5060;branch=z9hG4bK71b5401f596084541bb0894ae16bbbc8
From: <6103506982>;tag=3538245046-5121616103506982>
To: <>>3023522325@aa.aa.aa.aa(CUBE external IP)>
Date: Tue, 14 Feb 2012 21:52:37 GMT
Call-ID: 461523831-3538245046-512158@msc7.mydomain.com
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
*Feb 14 21:52:37.457: //395/0B18CF2B8382/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3023522325@xx.xx.xx.xx(UCMBE IP):5060 SIP/2.0
Via: SIP/2.0/UDP yy.yy.yy.yy(UC500/CUBE IP)>;:5060;branch=z9hG4bK2B4F4E
Remote-Party-ID: <>>6103506982@yy.yy.yy.yy(UC500/CUBE IP)>;party=calling;screen=no;privacy=full
To: <>>3023522325@xx.xx.xx.xx>
Call-ID: B1B3FCA-568D11E1-83889F30-EB9D8BD5@192.168.20.5
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 0186175275-1452085729-2206375728-3952970709
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1329256357
Contact:
Expires: 180
Max-Forwards: 69
Session-Expires: 3600;refresher=uac
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 246
v=0
o=CiscoSystemsSIP-GW-UserAgent 2063 472 IN IP4 yy.yy.yy.yy(UC500/CUBE IP)
s=SIP Call
c=IN IP4 yy.yy.yy.yy(UC500/CUBE IP)
t=0 0
m=audio 19566 RTP/AVP 0 101
c=IN IP4 192.168.20.5
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
*Feb 14 21:52:37.465: //395/0B18CF2B8382/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Tue, 14 Feb 2012 21:50:47 GMT
Allow-Events: presence
Content-Length: 0
To: <>>3023522325@xx.xx.xx.xx(UCMBE IP)>
Via: SIP/2.0/UDP yy.yy.yy.yy(UC500/CUBE IP):5060;branch=z9hG4bK2B4F4E
CSeq: 101 INVITE
*Feb 14 21:52:37.469: //395/0B18CF2B8382/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
02-16-2012 01:55 PM
So, I tried tried the rule /^.*/, and adding a rule to the sip profile to convert the anonymous@ip to anonymous@anonymou.invalid, but the calls still get through. Any comment on the debug output? Thanks
02-16-2012 11:40 PM
Try a SIP profile, eliminating Remote-party-ID altogether.
03-09-2012 07:43 PM
Try the following:
rule 1 reject /^$/
rule 2 reject /[^0-9]/
03-14-2012 05:06 PM
Have the same request and followed along but also not having success with getting it to work.
rule 1 reject /^$/ - Does not seem to match the unknown/private/anonymous calls
rule 2 reject /[^0-9]/ - Matches, however once the rule is put in any/all calls are rejected/blocked
Also, if a rule is added with a specific number, then that number will match and the call is rejected.
Thanks for any additional info!
03-14-2012 06:22 PM
The command "rule 2 reject /[^0-9]/" matches any CID that contains anything but a number. A similar command would be "rule 2 reject /^[^0-9]/", which means match CID that does not begin with a number. Try that.
For SIP calls, when a call is passed with no calling party number, the calling party number is set to anonymous, which does not match the "rule 1 reject /^$/" command because the calling party number is not null. Check the debugs to see exactly what the calling party number is.
03-15-2012 10:44 AM
Thanks for the super quick response.
rule 2 reject /^[^0-9]/ also appears to match any/all calls, but looking at the SIP debugs, it would seem that's happening because the SIP provider is sending inbound calls with a + mark before the number.
Here's an example of a non private call:
An example of a private/anonymous call (*67 before dialing):
Any possible suggestions to work around that? Thanks!
03-15-2012 10:58 AM
Try "rule 2 reject /[^0-9]$/".
Here is a good link to read up on regarding translation rules:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
03-15-2012 03:17 PM
That worked, thanks!!
03-09-2012 07:49 PM
Also, try modifying the disconnect cause to call-reject if the above doesn't work.
