04-22-2005 12:56 PM
Dear All:
Can i use cisco 7206 VXR to act as softswitch , handle the call routing between my customers and my gatewats.
Alaa Musa
04-22-2005 02:39 PM
Is it all going to be VOIP calls ?
04-22-2005 02:44 PM
Yes all of it will be VoIP calls
04-23-2005 07:49 AM
Its sounds like to me that you require the IPIPgw software, which is not available for the 7206, The Cisco Multiservice IP-to-IP Gateway is a special IOS software load that runs on the Cisco 2600XM, 3660, 3725 and 3745 series of multiservice gateway platforms only.
I had the same problem and had to but the 2610XM and IOS and licence to get up and running hairpinning VOIP calls!
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/index.html
Darren Frowen
