Dial-Peer with 2 voice port
lveraza
Hi, actually we have this voice network:
Branch -PBX - Router - WAN - Router - PBX - Core,
(E&M) (1 NM-HDV, with 2 E1, only one port is working now)
Now, we are lookig for a redundancy, first step, using both port
Branch - PBX - Router - WAN Router - PBX - Core
(2 E1 port working)
How can i have one dial-peer working for 2 port ?, if fails one, can work over another
Best regards, Luis.
Aaron Harrison
Hi Luis
You can't have one dial-peer pointing at two ports, but you can set up two identical dial-peers with different tag numbers.
Then set preference on each to set the priority:
dial-peer voice 1 pots
port 1
preference 1
... other commands....
dial-peer voice 2 pots
port 2
preference 2
.... other commmands....
The preference 1 is the highest (it's default, so it may not show up on your config) and pref 2 dial-peer will only be used if all channels on dial-peer 1 are in use or down.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
