Calling Party 'Unknown Number' over T1 PRI
sergiodovinte
I have a T1 PRI dms-100 over MGCP.
There is a Translation Pattern that routes the T1 numeration to a Hunt Pilot -2100-. This is a assigned to a Hunt List and a Line Group of extensions where the operators answer the calls.
My problem is that I'm not receiving the Calling Party number on the phones screens. I always receive 'Unknown number'.
I tried with different combinations on the T1 Gateway configuration (tried changing Calling party IE number type, Calling Numbering Plan, Display IE Delivery... etc). I have also checked into the Translation Patter that Use Calling Party's External Phone Number Mask is enabled, don't know if i have to enabled it on the Hunt Pilot too.
A debug q931:
Jan 11 18:12:33.466: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x0065
Jan 11 18:12:33.490: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8065
Jan 11 18:12:38.474: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0A0C
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98384
                Exclusive, Channel 4
        Progress Ind i = 0x8481 - Call not end-to-end ISDN, may have in-band info
        Called Party Number i = 0x80, '8XXXXXXXXX6'   <----------------- It Shows my T1 numeration OK
                Plan:Unknown, Type:Unknown
Jan 11 18:12:38.910: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8A0C
Jan 11 18:12:38.914: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8A0C
        Cause i = 0x80A2 - No circuit/channel available
Jan 11 18:12:38.942: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0A0C
Jan 11 18:12:39.126: ISDN Se0/1/0:23 Q931: TX -> NOTIFY pd = 8  callref = 0x860C
        Connected Address i = 0x80, '2100'  <----------------- It's the Hunt Pilot where the T1 is routed to in the Translation Pattern
        Notification Ind i = 0xF1
        Display i = 'XXXXXXXXXXXXX'
Jan 11 18:12:39.158: ISDN Se0/1/0:23 Q931: RX <- STATUS pd = 8  callref = 0x060C
        Cause i = 0x82E16E - Message type not implemented
        Call State i = 0x0A
Jan 11 18:12:39.362: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8A0C
Jan 11 18:12:46.186: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x860C
        Cause i = 0x8090 - Normal call clearing
The Operator Company says that this service is active by default on T1 PRI.
Any ideas?
paolo bevilacqua
Telco is not sending calling number.
If they claim otherwise, have them come on premises with their test equipment, and challenge them to show it to your eyes.
paolo bevilacqua
