01-11-2011 08:54 AM
I have a T1 PRI dms-100 over MGCP.
There is a Translation Pattern that routes the T1 numeration to a Hunt Pilot -2100-. This is a assigned to a Hunt List and a Line Group of extensions where the operators answer the calls.
My problem is that I'm not receiving the Calling Party number on the phones screens. I always receive 'Unknown number'.
I tried with different combinations on the T1 Gateway configuration (tried changing Calling party IE number type, Calling Numbering Plan, Display IE Delivery... etc). I have also checked into the Translation Patter that Use Calling Party's External Phone Number Mask is enabled, don't know if i have to enabled it on the Hunt Pilot too.
A debug q931:
Jan 11 18:12:33.466: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x0065
Jan 11 18:12:33.490: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8065
Jan 11 18:12:38.474: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0A0C
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98384
Exclusive, Channel 4
Progress Ind i = 0x8481 - Call not end-to-end ISDN, may have in-band info
Called Party Number i = 0x80, '8XXXXXXXXX6' <----------------- It Shows my T1 numeration OK
Plan:Unknown, Type:Unknown
Jan 11 18:12:38.910: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8A0C
Jan 11 18:12:38.914: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8A0C
Cause i = 0x80A2 - No circuit/channel available
Jan 11 18:12:38.942: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x0A0C
Jan 11 18:12:39.126: ISDN Se0/1/0:23 Q931: TX -> NOTIFY pd = 8 callref = 0x860C
Connected Address i = 0x80, '2100' <----------------- It's the Hunt Pilot where the T1 is routed to in the Translation Pattern
Notification Ind i = 0xF1
Display i = 'XXXXXXXXXXXXX'
Jan 11 18:12:39.158: ISDN Se0/1/0:23 Q931: RX <- STATUS pd = 8 callref = 0x060C
Cause i = 0x82E16E - Message type not implemented
Call State i = 0x0A
Jan 11 18:12:39.362: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8A0C
Jan 11 18:12:46.186: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x860C
Cause i = 0x8090 - Normal call clearing
Solved! Go to Solution.
01-13-2011 05:48 PM
Telco is not sending calling number.
If they claim otherwise, have them come on premises with their test equipment, and challenge them to show it to your eyes.
01-13-2011 05:48 PM
