CME 9.1 VoIP calls always directed to SIP-Proxy
Frank Hobrecht
Hi folks,
i have a strange problem on a CCME 9.1 (2921 ISG G2).
I have configured some internal voip dial-peers, which are pointing to SIP-Gateways in our internal network,
and one external voip dial-peer, which points to a SIP-Proxy of an external SIP-Provider.
If I dial an internal (4-digit) number, i.e. 5888, these calls are beeing directed to the external SIP-Proxy as well,
although they´re going through the correct "internal" dial-peer (i verified this with a debug).
Any ideas?
Here is the config:
voice service voip
ip address trusted list
  ipv4 10.16.17.18
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol pass-through g711ulaw
h323
sip
  localhost dns:acimex.com
  outbound-proxy ipv4:83.135.182.125
  g729 annexb-all
! Internal SIP-Gateway:
dial-peer voice 1001 voip
description MUC01
destination-pattern [1-8]...
session protocol sipv2
session target ipv4:10.16.17.18
session transport tcp
voice-class sip localhost dns:fti.int
! External SIP-Provider:
dial-peer voice 101 voip
description ** IP SIP Trunk to external provider **
destination-pattern 0.T
session target dns:as.vanillaip.com
session transport udp
incoming called-number 442085889906
no voice-class sip localhost
voice-class sip outbound-proxy ipv4:83.135.182.125
dtmf-relay rtp-nte
sip-ua
credentials username 12312313 password b realm a.b.com
authentication username 12312313 password b
no remote-party-id
retry invite 10
retry register 10
timers trying 1000
timers expires 300000
timers connect 1000
registrar dns:a.b.com
expires 3600
sip-server dns: a.b.com
If i dial i.e. 5888 it goes to the external Proxy 83.135.182.125, where it is rejected. It should go to the SIP-Gateway 10.16.17.18
specified in dial-peer 1001 instead.
Many thanks!
paolo bevilacqua
Wrong forum, post in "Voice - IP Telephony". You can move your post using the actions panel on the right.
