Configuring FAX
worldcalltel
i am using other vendor equipment for fax(Efax) using VoIP. my problem was everytime i check the calls. it can't go thru. i assumed is the bandwith bec. their using 512kb for voice and fax.is this an issue?coz they using the fax and voice calls at the same time using 512kb of BW. but when i try to use it at night when same problem occur.please help
rhugo
Level 3
Level 3
please post more detail of the environment:
1) how many IP Phone users?
2) Is the 512Kb JUST VOIP and Fax, or are there internet users and file servers, DB, etc
3) give more detail of the overall design / layout
Just an FYI on VOIP / Fax BW usage:
a single Fax call can consume 20kb - 80kb per call
a single VOIP call - 64k - 80k, depending on the codec used.
So, as you can see, a FULL T1 or, as many designs I've done in the past, a FULL T1 DEDICATED TO JUST FAX TRAFFIC!
I would say you are looking in the right direction. As to what you can do, depends on the environment and the money there is to spend. Here is a good Q & A white paper from a 3rd-party VOIP Fax SW vendor that really details VOIP and FAX traffic on new converged networks:
http://www.faxback.com/tools/White_Papers/Q&A.pdf#search=%22Efax%20with%20Cisco%20VOIP%22
worldcalltel
phone user/s = 30-50 users
512kb of BW is for fax, voice and internet
follow up question.!
i try to configure an cisco ATA and as5300 gateway
layout:
faxmachine/efax ---> cisco ATA ---> Gatekeeper ---> as5300
i got an error saying that it has an communication error and fax not respond. is there something wrong with these?
ATA Config:
Audio Mode?0xXXX5XXX5
Connect Mode?0xXXXX04XX
Rx Codec?3
Tx Codec?3
LBRCodec?3
AS5300 Config:
dial-peer voice xxx pots
description Testing-Fax
destination-pattern xxxt
port 0:D
description Int'l Testing-Fax
destination-pattern xxxT
port 0:D
prefix xxx
I would take the timer off of the destination-pattern:
xxxT
and change it to the most SPECIFIC dial peer that you can use:
destination-pattern 4001
no digit-strip
try that....
Also, if you want to look at the Fax Detect TCL script config as an option, here is a link:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1839/products_feature_guide_chapter09186a00800b5dc4.html
