CUCM and Avaya
cfujimura
I am integrating a CUCM 7.02 with a S8400 Avay PBX through h.323.
I added a h.323 gateway in CUCM with Avaya IP address and tested the integration.
But I only receive calls from Avaya PBX. I am not able to make calls from CUCM to Avaya.
The codec is setup to G711ulaw. I´ve tried  Fast Start with Media  Termination Point, but it didn´t work.
Does someone already experienced this kind of problem?
Aaron Harrison
Have you added a route pattern to point send calls to the H.323 gateway?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron, thanks for the reply.
Related to the route patterns, they are pointing to the gateway.
I solved the problem with CUBE. I´ve used a sip trunk to the cube and a H.323 call leg to avaya (I´ve configured that on CUBE).
After that, calls are working normally.
Carlos Fujimura.
