Data and Voice configuration on a switchport
pmpesha
Greeting,
What is the best configuration on the switchport for data and voice. The configuration will for a cat4500. Thank you
Brandon Buffin
In general, you seperate the traffic using VLANs - one VLAN for data, one voice voice. Take a look at the following link for a configuration example.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/20ewa/configuration/guide/voice.html#wp1044179
Hope this helps.
Brandon
thanks for replying, I do understand that I need two separate vlans for data and voice. Do I have to spesify the native vlan?, does the port have to a trunk port? Thank you.
If not specified the access vlan will be 1. If it is something different in your environment, you will need to specify it using "switchport access vlan x". You do not need to specifically configure a trunk. In the case of an IP phone the trunk is negotiated automatically.
Hope this helps.
Brandon
Thank you for your help
