07-07-2005 12:48 AM
I`m getting the following error on my router when i do a sh controller - the card in the PBX is showing out of service - could this be cisco or pbx related???Thanks
E1 5/0 is down.
Applique type is Channelized E1 - balanced
Description: **** Meridian PRI-loop 31 DCH33 Acod 1622 ****
Far End Block Errors Detected
Receiver has loss of signal.
alarm-trigger is not set
Version info Firmware: 20020306, FPGA: 11
Framing is CRC4, Line Code is HDB3, Clock Source is Line Primary.
07-07-2005 01:01 AM
Further to the message above, the sh ver returns this?
System returned to ROM by error - an Illegal Opcode exception, PC 0x62B10010 at
07:46:10 BST Thu Jul 7 2005
07-18-2005 07:24 PM
yuk...see if there is a crash file in flash or bootflash. If reboting it did not fix the issue, suspect bad memory first - if you are back up, setup to dump a crashfile.
Field notice:
http://www.cisco.com/en/US/products/hw/univgate/ps501/products_field_notice09186a0080094c9a.shtml
07-19-2005 04:45 PM
It's not plugged into anything -
You might need a E1 cross over cable using these pinouts to connect the PBX TX/RX to the router RX/TX -
1 ----- 4
2 ----- 5
4 ----- 1
5 ----- 2
