Enabling QoS in Cisco 877W
anishkgthomas
Hi all,
can anybody help me in configuring QoS on my cisco877W for VoIP below is the current config
Current configuration : 2670 bytes
version 12.4
no service pad
service password-encryption
hostname R877W
boot-start-marker
boot-end-marker
logging buffered 4096
no logging console
no logging monitor
enable password 7 01100F175804
no aaa new-model
dot11 syslog
dot11 ssid Cisco
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 1510070D072123253F38667446
ip cef
no ip dhcp use vrf connected
ip dhcp pool LAN
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   domain-name HomeLan
   dns-server 212.77.192.59 212.77.192.60
ip dhcp pool Wlan
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   domain-name WLAN
username admin privilege 15 password 7 104D000A0618
archive
log config
  hidekeys
bridge irb
interface Loopback0
no ip address
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
encryption mode ciphers tkip
ssid Cisco
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
channel 2447
station-role root
interface Vlan1
ip nat inside
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication pap chap callin
ppp chap hostname s4860348
ppp chap password 7 08304D5A080B5445
ppp pap sent-username s4860348 password 7 095D4F1D18174640
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
ip access-list extended vlan1-in
permit udp any eq 5060 any
deny   udp any gt 1024 any
deny   icmp any any
deny   igmp any any
deny   tcp any gt 1024 any
permit ip any any log
logging source-interface Loopback0
logging 192.168.10.29
access-list 10 permit any
arp 192.168.10.29 0021.5c6c.ab49 ARPA
control-plane
banner motd ^C
********** HOME ADSL ROUTER **************
****** UNAUTHORISED ACCESS PROHIBITED **** ^C
line con 0
login local
no modem enable
line aux 0
password 7 14160713
login
line vty 0 4
password 7 120D001B1C0E18
login
scheduler max-task-time 5000
end
paolo bevilacqua
Already asked in another thread, please do not open duplicates.
Sorry Paolo,
Was hoping to get a favourable reply. So far nothing. Do you happen to know the answer to this ?
I have replied to you in WAN and switching. Please remove duplicate threads.
