fxo configuration
a.kachroo
i have two routers each having two fxo cards and at each location one pstn line is terminated into one fxo port and other port is getting connected with the local epbx.
Now my question is how can i configure these routers,so that if i dial my pstn number outside say office A, that call will land in my office A (local) and in the second case my call will land at office B and in third case my call will land outside my office B.
Also i also want to dial from my office A to dial office B and outside office B.
I think this is possible but i am not getting the right configuration.
Arun Kachroo
7 Replies 7
thomas.chen
Level 6
Level 6
EPHRAIM MANI
Level 3
Level 3
Hi Arun let me know whether this issue got resolved.
Thanks EM
dford333
in your dial peer you want to set preferences
preferences 0 is default for
perference 1 office b
preference 2 office c
example
dial-peer voice 1 pots
description ** T1 PRI pots office 1 **
preference 1
destination-pattern 91.......... *office 1#*
port 0/1/0:23
forward-digits 11
description ** T1 PRI pots office 2 **
preference 2
destination-pattern 91.......... *office 2#*
port 0/1/0:23
forward-digits 11
preference 3
destination-pattern 91.......... *office 3#*
port 0/1/0:23
forward-digits 11
you have to translate the above for your topology.
Hopefully after 2 yrs 9 months the issue has been solved :)
you got to be kidding
Yes exactly :)
Posted by: a.kachroo - Dec 2, 2004, 4:59am PST
Anyway good job done but where's the A.kachroo the poster.
Thanks EM-
