01-18-2005 09:50 AM
I can not seem to get my 2821 which is acting as my CME and Gateway to pass off inbound calls. I can make outbound calls.
I believe I am having a dial-peer issue.
Can anyone help with suggestions, links for sample configs.
Thanks in advance,
Curt
01-19-2005 05:23 AM
Can you give more info - where can't you get inbound calls to go from/to? from pstn to voip, voip to voip, voip to pstn?
01-19-2005 02:41 PM
I'm not sure its Hairpinning but, I have 1 router which is providing CME\CUE\Gateway with 12 FXO lines. I can make VoIP calls to the PSTN thru the Gateway.
I can not recieve calls from the PSTN. The FXO port lights up and then disconnects.
I believe I am having Dial-peer issues.
01-19-2005 07:43 PM
Do you have your codec set to G711?
01-20-2005 06:56 AM
Can you post your dial-peer and port configs?
01-21-2005 10:21 AM
It seems like I am having a Dial-peer issue. Here is my orginal Dial-peer plan. I have since then tried different methods.
This plan is very similar to another installation I am running with 1 router for CME and 1 router for my gateway. and I have only specified the codec under my dial-peers.
I have a PVDM2-16 and 48.
