Help needed with LLQ on ATM subinterfaces
dukenukem
Hi all,
I am currently trying to implement LLQ on an ATM to FR 2 Mbps connection. My certification is only up to CCNA and then i learn what i need to use. Now i need to learn QoS.
I have been told to use LLQ for prioritizing my voice traffic. I am trying to specify a class, where i will use an extended ACL to specify that from host 10.51.22.241 to host 10.51.12.7 (my IPs for the two PBX systems) i am not using IP Phone, but VOIP Cards iu Siemens PBX. SO i am only interested in the traffic generated by those IPs.
I specify the class-map, then my policy map, but when i try to implement it on the ATM subinterface, it refuses to work, giving me an error message that CBWFQ is not supoprted on ATM subinterface.
I am including the configuration portion of this setup, and i also show you the error messages i received.
Is there a workaround for this, or any other info or mechanism i could use.
Any help will be greatly appreciated.
George
Sample Code and output
class-map match-any VOIP-CLASS
match access-group 101
policy-map VOIP-POLICY
class VOIP-CLASS
priority 300
access-list 101 permit ip host 10.51.22.241 host 10.51.12.7
IACSrouter#conf t
Enter configuration commands, one per line. End with CNTL/Z.
IACSrouter(config)#exit
IACSrouter#conf t
IACSrouter(config)#int atm1/0.49
IACSrouter(config-subif)#service-policy output VOIP-POLICY
CBWFQ : Not supported on subinterfaces
IACSrouter(config-subif)#exit
IACSrouter(config)#int atm 1/0
IACSrouter(config-if)#service-policy output VOIP-POLICY
CBWFQ : Not supported on this interface
Aaron Harrison
Go to this url:
www.cisco.com/go/srnd
And download the QOS SRND. On page 135 there is a handy example of how to configure QOS on a frame-to-atm link which is probably what you need.
There's also a lot of very useful QoS info throughout the document.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
d.rocco
George,
You could try to apply "service-policy output" command under the pvc submenu.
For example:
interface ATM1/0
ip address 1.1.1.1 255.255.255.252
pvc 10/140
vbr-nrt 768 256 1
encapsulation aal5snap
service-policy output QoS-Primary-Varone
Hi Diego
pkokhan
Does your atm subinterface contain line starting with "pvc"? If so go to pvc configuration and try applying the policy there
Make sure that you have IP CEF turned on. You can only apply a service policy on the atm interface if it does not have pvc's. If it has pvc's the service policy must be applied there.
