HICOM100
ldulik
Has anybody connected PBX HICOM100 to Cisco router with VIC 2B-NT/TE. ISDN is ACTIVE but there is a message in Release_Comp "Invalid information element contents" in debug isdn q931 output when I try to call. I have set router as NT (the only possible setting towards HICOM100).
Can it ever run?
owillins
Level 6
Level 6
This indicates that the equipment sending this message has received an information element, but one or more of the fields in the information element are coded in a way that has not been implemented by the equipment sending this message. Generally this is due to a D-channel error. You could check for the bearer capabilty and make sure that the correct G.711 u-Law/a-law is applied.
pacameron
Level 4
Level 4
We got one working by using a switch type of QSIG even though the PBX config screen said it was set to Net3 switch type , but if you are seeing clearing codes of invalid IE contents this sounds like the switch type is OK. Can we get a log from debug ISDN Q931 for a failed call ?
