How can I block certains calls from the specific FXS ports?
SludnevTN_2
I have to block the use of dial-peer voice 9 voip from the voice-port 1/2, what technology shold I use? COR? but I can not find clear documentation for me, please help me thank you.
voice-port 1/0
cptone RU
timeouts wait-release 5
voice-port 1/1
cptone RU
voice-port 1/2
cptone RU
voice-port 1/3
cptone RU
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 244
port 1/0
dial-peer voice 2 pots
destination-pattern 241
port 1/1
dial-peer voice 3 pots
destination-pattern 242
port 1/2
dial-peer voice 4 pots
destination-pattern 243
port 1/3
dial-peer voice 5 pots
dial-peer voice 6 pots
destination-pattern 245
dial-peer voice 7 pots
destination-pattern 246
dial-peer voice 8 pots
destination-pattern 247
dial-peer voice 10 voip
description ---- Central Office ----
destination-pattern 1..
session target ipv4:192.168.254.1
codec g729r8 bytes 40
description ---- Town destination ----
destination-pattern 9[1-6,9].....
5 Replies 5
Brandon Buffin
Here's one way to do this:
voice translation-rule 1
rule 1 reject /^9[1-69]/
voice translation-profile profile1
translate called 1
voice-port 1/2
translation-profile outgoing profile1
Hope this helps. If so, please rate the post.
Brandon
dont know why but this did not help here is debug:
Mar 6 14:18:15.358: regxrule_get_profile_from_trunkgroup: Voice port 0x81F778CC does not belong to any trunk group
Mar 6 14:18:15.366: regxrule_stack_pop_RegXruleNumInfo: stack=0x82250E38; count=1
Mar 6 14:18:15.370: regxrule_stack_push_RegXruleNumInfo: stack=0x82250E38; count=0
Mar 6 14:18:15.370: regxrule_profile_translate: number=244 type=unknown plan=unknown numbertype=calling
Mar 6 14:18:15.370: regxrule_match: No match; number=244 rule precedence=1
Mar 6 14:18:15.370: regxrule_profile_match: No match found
Mar 6 14:18:15.370: regxrule_profile_translate: No match: number=244 type=unknown plan=unknown
Mar 6 14:18:15.370: regxrule_profile_translate: number= type=unknown plan=unknown numbertype=redirect-called
Mar 6 14:18:15.374: regxrule_get_RegXrule: Invalid translation ruleset tag=0
Mar 6 14:18:15.374: regxrule_profile_match: Error: ruleset for redirect-called number not found
Mar 6 14:18:15.374: regxrule_profile_translate: No match: number= type=unknown plan=unknown
Mar 6 14:18:16.454: regxrule_profile_translate: number=9 type=unknown plan=unknown numbertype=called
Mar 6 14:18:16.454: regxrule_match: No match; number=9 rule precedence=1
Mar 6 14:18:16.454: regxrule_profile_match: No match found
Mar 6 14:18:16.454: regxrule_profile_translate: No match: number=9 type=unknown plan=unknown
Mar 6 14:18:17.794: regxrule_profile_translate: number=92 type=unknown plan=unknown numbertype=called
Mar 6 14:18:17.794: regxrule_match: No match; number=92 rule precedence=1
Mar 6 14:18:17.794: regxrule_profile_match: No match found
_______________________________________
I have shanged one thing:
translation-rule 1
Rule 0 ^9 0
voice-port 1/2
translate called 1
I do not have any dial-peer that mathes 0, so the problem is solved. Thank you for an idea. Please tell me what is the difference between:
"translation rule" - works for me.
"voice translation rule" - did not worked.
The "translation-rule" command is an older command. The "voice translation-rule" command is the recommended way to manipulate digits and is more flexible. They also have slightly different syntax. That being said, if this config using "translation-rule" works, by all means use it.
Brandon
Brandon, why "voice translation rule" did not work? How can I make them work? Thank you.
Using the previous config that I suggested, try changing the translation profile under the voice port to "translation-profile incoming profile1".
Brandon
