How to enable h323-remote-address in RADIUS Accounting Start messages?
alanwright1
As the title states, how do I enable h323-remote-address AVP to be sent from a Cisco ISR 15.1-4M8, to a RADIUS server.
So far, I only see this AVP in the accounting stop, which is rather pointless
BR
ALan
Hi Alan, do you have already check these commands:
aaa accounting connection h323
To define the accounting method list H.323 with RADIUS as a method with either stop-only or start-stop accounting options, use the aaa accounting connection h323 command in global configuration mode. To disable the use of this accounting method list, use the no form of this command.
aaa accounting connection h323 {stop-only | start-stop | none} [broadcast] group groupname
no aaa accounting connection h323 {stop-only | start-stop | none} [broadcast] group groupname
Regards.
